front brake pads
front brake pads
So I thought working on the front brakes today would be a piece of cake compared to the rear pads I replaced yesterday. Boy was a I wrong! So I loosened the 2 caliper bolts on the passenger side. It's not a typical retaining bolt that you loosen and lift up the caliper. Instead, the head of the bolt is an inverted hex. I used a 3/8 hex socket and loosened each of the 2 caliper bolts for what seemed like 30 minutes each, but I still cannot get the caliper free from the rotor? How do I finish this job? This car is by far the worst I've worked on as far as brakes go, ugggh!
