LT1/LT4 Tech 1993-1997
Forgot to take pics- Vacuum line connections
Old Mar 15, 2012 | 03:21 PM
borjawil's Avatar
well i just turned the crank for the second set. I noticed some of the rockers i already tightened are loose. should they be loose?
Old Mar 15, 2012 | 03:50 PM
then those valves were not closed all the way or the lifters have blead off some oil. lets see what i can find, be right back. so long as you followed the links aready provided you should at least get them close enought to start. did you prime the oil system before installing the intake. are the lifters new or the originals? i read several different write ups on the lt1 to make sure of any changes that may have been made from the last time i had set lifters.
Old Mar 15, 2012 | 07:16 PM
borjawil's Avatar
Not sure how to prime the oil system? everything is original. Just wanted to replace the head gaskets and slap it back together.
Old Mar 15, 2012 | 08:06 PM
ok wasnt sure if the lifters were new. there not dont worry about priming. so if you followed the shbox link you should have the lifters done close enough to start the motor and set them while its running.
Old Mar 16, 2012 | 07:50 AM
borjawil's Avatar
Even if I set them on the wrong stroke itll still run with no ill effects?
Old Mar 16, 2012 | 10:07 AM
so long as the cam lobe is not pushing up on the lifter then the rocker will set close enough to run. best to wait for the intake valve to close all the way, go a tad farther and set but so long as the rocker/lifter has come down and closed the valve all the way you can set that rocker, you dont want to over tighten the rockers or have them to lose.
Old Mar 17, 2012 | 02:26 PM
borjawil's Avatar
ok getting things back together cant seem to figure out where a couple things go first thing is on the passenger side of the intake manifold there are two smaller nipples. Not sure where either goes. Think ive got everything else hooked up correctly. Just need to get these figured out and I can start getting it ready to be run. Thanks for all the help so far guys!
One other thing since I have to set the valves while its running Theres no point in putting the valve covers on right? And should I fill it with oil through both heads or just the one that had the oil fill on the valve cover?
Old Mar 17, 2012 | 04:48 PM
May want to look at this. Just make sure to pick the right engine.
| Repair Guides | Vacuum Diagrams | Vacuum Diagrams | AutoZone.com
Old Mar 17, 2012 | 09:40 PM
you should dump oil on all the rockers then it dosnt matter what side or both. the lt1 does not throw alot of oil but its not hard to remove or install the driver side so put it on and do the passenger side first. i just sat mine on there and made sure is was placed right so it wouldnt hit the rockers.
Old Mar 21, 2012 | 04:43 PM
  #20
borjawil's Avatar
looked at the diagrams. think I got it figured out. heres a wordpaint portrayal of what ive got. the orange lines are orange simply to separate them from the black lines that they over lap.
