LT1/LT4 Tech 1993-1997
Fans won't come on 97 30th Anv.
Old May 2, 2007 | 03:54 AM
jaimejames2's Avatar
Default Fans won't come on 97 30th Anv.
I have checked all fuses and even the sensor on radiator. What could it be? My Temp. gage is working because it tells me when the car is getting to hot and the fans just won't turn on! Please some one help me out![]
Old May 2, 2007 | 05:59 AM
chrshadil's Avatar
Default RE: Fans won't come on 97 30th Anv.
Did you check your relays also, one of them could be burned out. On my 94 Z28 there is three relays that work the fans.
Old May 2, 2007 | 07:33 PM
The fans are controlled by the PCM using 3 relays. Turn on the AC & the fans should run, if not you have an electrical or relay problem. The PCM looks at the ECT sensor mounted on the engine to determine coolant temp. There is no temp sensor on the radiator. See the sticky on the LT1 section on how to analyze your problem.
Hotruber
Jul 29, 2009 02:48 PM
BIGMIKE
Sep 6, 2007 02:52 AM
30thanvSS
Aug 14, 2007 02:20 PM
BIGMIKE
Feb 18, 2007 01:40 PM
BIGMIKE
Feb 5, 2007 01:27 AM
