LT1/LT4 Tech 1993-1997
failed emission test trans related please help !!
Old Sep 7, 2006 | 04:58 PM
randscr's Avatar
Default failed emission test trans related please help !!
i failed my test and was wondering if you can help me. the code p0719 ( torque converter / brake switch b circuit low). do i need to replace the switch ? someone told me that its a power or ground issue, does anyone know what i shoud do to correct this ? also where is the switch located ? thank you for you advice. jim
Old Sep 8, 2006 | 02:33 AM
Default RE: failed emission test trans related please help !!
Try adjusting the cruise control release switch as it also controls the TCC.
Top switch on brake pedal.
Old Sep 8, 2006 | 10:47 AM
randscr's Avatar
thank you very much pete.
jim
danger_5150
82-92 V8 Tech
Jul 15, 2010 08:38 PM
Clutch_Z28
Apr 4, 2009 07:49 AM
sixty6
82-92 V6 Tech
Aug 18, 2008 12:52 PM
94CamaroSFI
LS Series Tech
Oct 29, 2006 01:14 AM
randscr
Sep 8, 2006 10:48 AM
