engine swap
RE: engine swap
The motors are based off the same block, so it should fit without any real issues. You're going to need to find places to put all the electronic stuff if you're going to keep it EFI. Theoretically you should be able to bolt it right in, but there may be some clearance issues because of the Opti on the front of the engine etc.
