electric water pump
GM LT-1 Electric Water Pump
In The Box You Will Find:
1 1-1/8 deep brass freeze plug PC25B
1 Wiring harness w/ 20 amp fuse
2 Contingency stickers
To Do The Job You Will Need:
· A few metric hand tools
· Hydraulic press
· Scraper or wire brush
· Brake cleaner
· Recommended sealant; Form A Gasket (aviation), Form A Gasket 2 (Non-Hardening), Gaskacinch or RTV silicone
· Factory water pump housing to block gaskets P/N 10128343
· Factory inspection cover o-ring P/N 10128329
· Grease or Vaseline (petroleum jelly)
Disassembly
Remove factory water pump housing. Remove the six-bolt inspection cover. Clean the mounting surface on the housing and the engine block. At this point the stock mechanical pump components must be removed from the housing (i.e. impeller and bearing / seal assy.). Some technical experience is required. If you do not have access to the proper equipment or feel unqualified, please consult an automotive machine shop for help in completing this part of the job.
Place the housing face up in the hydraulic press resting the gasket surface centered on the shaft. It is necessary to support the back of the pump housing near the water neck to prevent it from rocking back when force is applied by the press. Use a pin or dowel (about 5/16 x 1 ½) to press the bearing assembly out of the impeller and housing.
Assembly
Clean the bearing bore and install the supplied freeze plug from the inside of the pump use Permatex Form A Gasket or Loctite Sleeve/Bearing retainer on the bore. You may choose to plug some of the factory water ports at this time. Now you are ready to reinstall the pump housing, the Meziere pump can be mounted before or after the pump housing is installed on the engine. Use recommended sealant on the factory-mounting gasket. No sealant is used on the o-ring seal grease or Vaseline can be used to lubricate the o-ring to prevent pinching or twisting. Reuse the factory inspection cover bolts to attach the Meziere pump (do not over tighten).
Wiring
The BLUE wire connects to positive (+)
The BLACK wire connects to chassis ground or battery negative (-)
TO AVOID MOTOR FAILURE, be sure to use the fuse holder supplied with the harness or install your own 15 to 20 amp fuse and holder WARNING: NOT USING A PROTECTION CIRCUIT CAN VOID YOUR WARRANTTY.
Running
Fill the cooling system. Replace fill cap and turn on pump. Remove fill cap and top off coolant level. Recheck level after one heat cycle. DO NOT RUN PUMP DRY for more than a few seconds.
[size=2]Beauty TipYour pump comes to you polished and waxed. An occasional waxing will allow dirt or debris to
· Hydraulic press
· Brake cleaner
Disassembly
Assembly
Wiring
Running
