LT1/LT4 Tech 1993-1997
Eating Waterpumps
Old Aug 19, 2008 | 04:16 PM
lt4weeda's Avatar
Default Eating Waterpumps
ok heres the deal ive got a 94 z and i have gone through 3 water pumps in 5000 miles. Every water pump has lasted me about 3 weeks then i start to get an antifreeze leak. after the second one i replaced all of the heater hoses. , but i can't find anywhere it is leaking from. Also the car never leaks until i am driving the car if i just let the car idle in the driveway it doesnt leak. I was wondering if there was a common problem with this with lt1's or if I've got some major issues. The only other thing i can thing off would be a bad head gasket but then the engine only has 30,000 miles on it. Any help would be much appreciated
Thanks
Old Aug 19, 2008 | 08:15 PM
Default RE: Eating Waterpumps
Check your radiator cap and the overflow tank. Coolant when heated expands and flows into the overflow tank, and then gets sucked back into the radiator when the engine cools down. A malfunction in this part of the system can cause loss of coolant. The LT1 water pump (from GM) is a pretty reliable part so you shouldn't be having to change them for at least 70K miles.
Old Aug 20, 2008 | 07:27 PM
noz's Avatar
noz
if you think you have bad head gaskets check your oil if they're bad your oil should be milky.....
libertyforall1776
LS Series Tech
May 14, 2009 02:42 PM
armynatguard18
VS
May 20, 2008 01:22 AM
Kblerelfs
Nov 16, 2006 10:55 PM
