LT1/LT4 Tech 1993-1997
Eagle Rotating Assembly Crank has a Key, but My Hub Shaft Dont..
Old 01-31-2011, 11:24 PM
wicked94z28's Avatar
Actually I did some Research and Im just going to have a local shop slot my hub tomarrow only 25 bucks and seems to be the better route.. is there any certain place he should slot it? or just do it anywhere?
Old 02-01-2011, 05:42 AM
may as well have it done so the arrow points up.
Old 02-05-2011, 03:30 AM
marten's Avatar
taking away metal work reduce the weight wouldn't you have to get it rebalanced then?
Old 02-07-2011, 12:10 AM
not for sure.. i bought one from thunder racing so hopefully it dont need balanced
Old 02-07-2011, 12:19 AM
no you wouldnt. even if you had the orginal machined the key would replace about the same amount of weight.
NorthernCrew454
08-06-2013 07:27 AM
EdPDX
08-20-2011 05:31 PM
NorthernCrew454
06-04-2011 06:08 PM
NorthernCrew454
05-01-2011 09:35 PM
microkid
02-22-2007 12:13 AM
Quick Reply: Eagle Rotating Assembly Crank has a Key, but My Hub Shaft Dont..
