LT1/LT4 Tech 1993-1997
dont know whats wrong
Old Mar 21, 2006 | 11:44 AM
97BAMF's Avatar
Default dont know whats wrong
i have a 97 Z28 and when i try to start it sometimes it fires right up then other times it takes 2-3 cranks. And also after im done driving it smells like fuel and like its running way to rich
Old Mar 23, 2006 | 11:32 PM
mike86rs's Avatar
Default RE: dont know whats wrong
Im not sure if this could be the problem but is your fuel pressure regulator bad?
Old Mar 24, 2006 | 07:08 PM
TimmyTheWop89's Avatar
if its running rich then you have to adjust your car. what kind of carb is it? if its an edelbrock, turn both screws in one full turn. drive it around and see hwat happens.
Old Mar 24, 2006 | 08:26 PM
97BAMF's Avatar
its fuel injection so i dont really know wut to do
Old Mar 24, 2006 | 08:50 PM
oh dont think i can help ya there. perhaps you have too much fuel pressure or a bad regulator. you buy a new fuel pump lately? cant really point my finger on anything else, dont kno much about fuel injection problems.
Old Aug 31, 2006 | 01:05 AM
ANARCHY67's Avatar
sound like maybe your charcoal cannister may be full or perhaps a vent line may be kinked
Old Sep 5, 2006 | 07:31 PM
civickiller2.5's Avatar
It could not be your fuel system.....
Try checking your spark plug wires at your local shop, and the plugs while your at it.
My advise is to the easy, less expensive stuff first
o yeah you might wanna clean out the injectors too, if any thing it might give you a little more MPG
Old Sep 6, 2006 | 02:34 AM
You may have a leaky injector or bad check valve in fuel pump as they could produce the symptoms you mentioned. Check the fuel pressure & see if it holds after engine is turned off.
Old Sep 6, 2006 | 03:09 AM
uncle bill's Avatar
Run the codes, sounds like a bad Oxygen Sensor?
94ChevyCamaroV6
Feb 9, 2012 11:28 AM
95MCCamaro
Mar 21, 2010 06:44 AM
krdono2
May 24, 2009 11:39 AM
White86IROC-Z
82-92 V8 Tech
Apr 4, 2009 12:15 AM
