LT1/LT4 Tech 1993-1997
distributor cap and rotor replacement
Old Jul 7, 2007 | 10:33 AM
ttustud07's Avatar
Default distributor cap and rotor replacement
need help on how to changethe distributor cap and rotor.
i have a 1996 camaro 5.7L v8.
Old Jul 7, 2007 | 10:51 AM
TrammelZ28's Avatar
Default RE: distributor cap and rotor replacement
i have never changed mine but on other cars i have done the cap just pops of and the rotor will unscrew or pull off, but the reason i posted is wondering how many miles u have on the car, if you havnt already bought the cap and rotor you might want to buy a whole new distributor from somewhere like summitracing they come with a new cap and rotor with the distributor.
Old Jul 7, 2007 | 11:25 AM
ttustud07's Avatar
it has 128k miles. the cap and rotor are behind the main pulley. and i was wonderin wut the easiest way to change it would be
Old Jul 7, 2007 | 12:57 PM
JD1969's Avatar
You need to pull the radiator and fans, remove the acc. belt, water pump, and crank pulley. You now should be able to get to the distributor. I am sure I forgot a few little things but that's the basics.
Old Jul 16, 2007 | 10:48 PM
4footer's Avatar
i jus changedmy opti spark to a msd. i love it and itgives a hotter spark at that. it was fairly simple. i didn't remove the radiator, just the waterpump altinator and and hoses. it was pritty easy easy from the bottom to replace. if anyone hasany questions on the opti spark and transremovel. let me know, im willing to lend advice..... so hit me up. ttyl
ZackD1212
67-69 V8 Tech
Jun 5, 2014 11:16 PM
Chevy101
Sep 23, 2011 04:21 PM
gagger84
Aug 18, 2009 10:19 PM
tjmyktn
Jul 9, 2009 11:45 AM
CamaroSS2045
May 21, 2008 11:28 AM
