Rotor Upgrade
Old May 7, 2008 | 07:21 PM
CamaroSS2045's Avatar
Default Rotor Upgrade
I know the factory rotors are garbage, but other than that I don't know much. Would just about any slotted and/or drilled rotor be better than factory or do I need to get expensive ones? Any help would be appreciated.
Old May 7, 2008 | 09:48 PM
bluovlh8er's Avatar
Default RE: Rotor Upgrade
the slotted/drilled rottors help with heat disribution. also zinc plated looks nice too.
search ebay you can get all 4 rotors+rads for under $200
Old May 8, 2008 | 09:11 AM
Is it worth upgrading the back brakes?
Old May 8, 2008 | 10:19 AM
libertyforall1776's Avatar
Also consider replacing your rubber brake hoses with stainless steel braided for improved performance, you will notice the improvement.
Old May 21, 2008 | 11:28 AM
wguy0122's Avatar
If you go to http://brakeperformance.com and you can get dimpled and slotted rotors, they are lifetime guaranteed against warping and they are less likely to crack, they are zinc also so they wont rust.you also get a free set of performance pads if you buy front and back rotors.
Chevy101
Oct 17, 2011 06:43 AM
Chevy101
Sep 23, 2011 04:21 PM
pit257
Mar 2, 2011 09:07 PM
auto
Aug 9, 2010 08:48 AM
chrshadil
Aug 25, 2007 10:33 PM
