Cruise control quit
Cruise control quit
Vehicle: 1995 Z28 M6 Convertible
My cruise just quit. I checked the relay and fuse and they are intact. My third brake light also works. Any ideas why it would just quit? is there anything I can check or do I need to pull codes (I have no SES)? Thanks.
x01660
x01660
Follow the second cable to the cruise control unit and check to make sure that it is plugged in and there is no corrosion on the connector. If memory serves me right it is below the air cleaner next to the air pump on the driver's side. This area of the car gets alot of messy stuff from driving so the plug could need some help. If that is it and the plug gets cleaned and working again I would get some dielectric grease and fill the socket up with that to protect against future corrosion
Massey
Massey
