Cruise Control
my cc in the first 93 quit working and it was the switch in the blinker handle. picked up a new one and worked fine. it would work then not then work etc. one day it wouldnt work anymore.
here is wiring for 93 you have a body control module in there, here is wiring for it http://shbox.com/1/bcm_1996.jpg
The short explanation I found somewhere online was that the wheel speed sensor on the rear axle gets its power in series through the third brake light. So if the third brake light is burnt out, then no voltage can get to the speed sensor, and therefore no ABS or CC. Also, if you replace the standard bulbs with LEDs, then you need to also add an automotive relay into the wiring to get everything to work again (though I cannot remember the reason why).
I know this because when I bought mine a few years ago, I had the "ABS INOP" light and no cruise control and my third brake lights were burnt out. Once I fixed the third brake lights, my CC started working and the "ABS INOP" light went out.
I would suspect that the third brake light being out would affect a '93 in similar manner.
