- - Cruise Control
(https://camaroforums.com/forum/lt1-lt4-tech-9/cruise-control-70857/)
madmax32
07-23-2012 09:33 AM
Cruise Control
97 Camaro z28 Cruise Control Inop. Any suggestion i've looked at all the fuses no avail. Any Suggestions? Only thing I can think of as a posiblilty is the switch.
Grandpaswagon
07-23-2012 04:12 PM
Has it ever worked while you owned the car or is this loss of CC something new?
BasicConcepts
07-23-2012 04:15 PM
doesnt the cc go out if one of the brake lights are out? i thought i read that somewhere.
GreenMamba
07-23-2012 06:23 PM
Doesnt a brake light being out also trip the "abs inop" light? Reason i ask is because my light is on and my cc is no good either... maybe i need to check that:)
BasicConcepts
07-23-2012 07:26 PM
ya im pretty sure the third brake light will trip the abs inop but i swear i remember someone saying it will shut down the cc too
craby
07-24-2012 01:50 AM
yep i have heard the same thing, from pete i think. i dont know because my center light has never went out. lol now it will.
madmax32
07-24-2012 09:21 AM
It has worked before but now it doesn't. I'm at a loss
craby
07-24-2012 09:44 AM
my cc in the first 93 quit working and it was the switch in the blinker handle. picked up a new one and worked fine. it would work then not then work etc. one day it wouldnt work anymore.
I know for a fact the third brake light being out will cause an "ABS INOP" light on the dash and loss of cruise control on the '94 Z28s. However, GM rewired the system in '96 or '97 IIRC to fix this issue.
The short explanation I found somewhere online was that the wheel speed sensor on the rear axle gets its power in series through the third brake light. So if the third brake light is burnt out, then no voltage can get to the speed sensor, and therefore no ABS or CC. Also, if you replace the standard bulbs with LEDs, then you need to also add an automotive relay into the wiring to get everything to work again (though I cannot remember the reason why).
I know this because when I bought mine a few years ago, I had the "ABS INOP" light and no cruise control and my third brake lights were burnt out. Once I fixed the third brake lights, my CC started working and the "ABS INOP" light went out.
I would suspect that the third brake light being out would affect a '93 in similar manner.
