LT1/LT4 Tech 1993-1997
CraZ28's Engine Build Thread
Old 02-23-2010 | 01:44 PM
whammer3024's Avatar
ROTM Winner
you're taking your engine to a machine shop and don't think they will have the stuff you need?
  #42
Old 02-23-2010 | 02:17 PM
CraZ28's Avatar
Banned
No. I have to have my keyed hub for balancing and my main girdle for him to torque/check/main honeing.
  #43
Old 02-23-2010 | 02:38 PM
Originally Posted by CraZ28
I know all that. That's stroker basics. When you order Wiseco pistons is has all the compression ratings and rod length specs. I am more worried about cam clearance. And no one has answered my question about a loose fitting pilotbearing. I'm thinking about going Kevlar bushing now?
So why did you aske the question, why part numbers were different for the longer rods?
  #44
Old 02-23-2010 | 02:50 PM
CraZ28's Avatar
Banned
I think the question I had for you was why are there different cranks for the size of the rod, I know the pistons are not the same.
  #45
Old 02-23-2010 | 04:35 PM
CraZ28's Avatar
Banned
Just ordered my Keyed Hub from Jegs. It looks like a nice piece. Three holes tapped for the balancer and a keyway so you don't have to beat the hell out of it to get it on the crank.
  #46
Old 02-23-2010 | 07:39 PM
u know if u put the hub in some hot water for a while and let it heat up good it will go on easier. should not be beatin on the balancer.
  #47
Old 02-23-2010 | 07:46 PM
dang and i wasnt going to post on this thread. lol. so how much play in the bearing. if the motor is going to be balanced i would think u would want a tight fit.
  #48
Old 02-23-2010 | 08:28 PM
CraZ28's Avatar
Banned
Good question Crab. It has to be installed before balancing? Maybe I should let my machinist handle it. I'll ask him tomorrow how to handle a loose fitting pilot bearing. And I am tired of messing with that dam keyless hub. When I first removed it I broke four pullers and heated it up until the crank gasket melted. Then I figured out about the center pin method. It is just too tight. The last time i installed it I hammered on it for about a half hour before it seated on the crank. Then I had to grind it so the balancer would go on! Lesson learned. Plus now I'm thinking about converting to a big blower on top!
  #49
Old 02-23-2010 | 08:59 PM
ROTM Winner
then you're going to want different pistons to lower the compression...and i definitely wouldn't trust the chinese crap you've been putting in your motor if you're going with a blower. but whatever you think you need to do
  #50
Old 02-23-2010 | 11:11 PM
CraZ28's Avatar
Banned
Ya, thanks hammer. You can also change compression by heads or thick gaskets. My car is a street emissions regulated car, I don't need billet steel stuff! And all the American made stuff is too expensive for me, that's for the rich guys. But I sure do like the new style blowers they got out now!
Quick Reply: CraZ28's Engine Build Thread
