LT1/LT4 Tech 1993-1997
Cooling question
Old 05-12-2007, 03:00 PM
Altekameraden's Avatar
Default Cooling question
Only reason im asking is because search option wont work on my comp.
I have a 93 z28 and the redline mark on the temperature gauge is almost reached if im driving around in city traffic but if i get on the interstate with speeds above 50 it cools back to about 200
im worried about pushing that 240+ which i hit pretty quick ne help thanks for
Old 05-12-2007, 10:33 PM
Default RE: Cooling question
Are the fans running?
Old 05-12-2007, 11:54 PM
usarmyrangrs's Avatar
Make sure you have enough coolant in the system, too. Crack the bleeder screw and open the radiator cap. Fill it up if it's low. 9 times out of 10, overheating is caused by not knowing how much coolant is in the system. I had the same problem. I thought my levels were just fine. Come to find out, it was nearly bone dry, due to a parasitic leak at the water pump. After replacing that and filling the system back up, I'm in city traffic and she's holding just below 200F.
95ConvertibleRo
05-17-2013 01:09 AM
Camambro
04-25-2012 07:05 PM
68RS
05-30-2010 02:09 PM
Marty
07-30-2009 12:49 AM
sewerrat
04-23-2009 11:22 AM
Quick Reply: Cooling question
