Coolant passages in block
Whats up guys? I know I haven't been on in a long while, but I've been so busy with work and the Camaro.
Well about the Z...long story short, I did heads, cam, etc and I noticed coolant mixed in the oil. Not sure what it was, so I took the heads off and cleaned the block and heads and looked for cracks and what not. No obvious cracks, but I did notice one thing. All of the head bolt holes on the passenger side at least all look like they are either all the way open or somewhat open to the coolant passages. Is this true about this motor? The new head bolts come with sealant on them just like the old ones did, but I bought loctite thread sealer and I will add that to each bolt.
But I'm curious if the holes should be exposed to the coolant passages or not?
have the oil cooler pressure checked. its between the oil filter and the block. other than that did you see any indication it was leaking by a head gasket? ive had problems getting a headgasket to seal before. it showed on the compression check and the gasket. it did make it way easier to know where to look though. had to switch to a better gasket. it was on a boat so i went with volvo. cometic makes a really good head gasket to.
Fill the threads of your head bolts with a sealer that contains teflon (aka PTFE). ARP #100-9904 Sealer or Permatex's Ultra Black would do just fine. Use assembly lube around the washer area of the head bolts to make sure everything torques properly.
Also, I noticed that the top most bolts that sit in between the rockers, the holes in the block on the passenger side had little holes in them, but the same holes on the driver side were solid. So I think I may have hydro-locked those holes when going together, but still, the bolts had sealer on them. Jesus, I'm confused.
Update: I did the head gaskets and head bolts and applied permatex ultra black and torqued them down to spec as per GM service information. I'm not sure if it was residual oil in there or what, but I dropped the cheap oil I put in to clean it and it still seemed milky, but not as milky as before.
As stated, I did the head gaskets, head bolts with sealant. I don't have an oil cooler. I'm not sure what else it can be besides a crack in the heads or block.
Well, I kept pouring one quart of oil at a time and letting it drain, and then shooting air into the drain plug pushing ALOT more out than just letting it drain. After doing that about 6 times, it looks like the new cheap oil in there now isn't milky so it was residual oil.
AnalyzeFaith
12-05-2010 05:54 PM
