LT1/LT4 Tech 1993-1997
coolant level low symbol need help!!!!
Old 09-17-2007, 09:23 PM
stud1502's Avatar
Default coolant level low symbol need help!!!!
i have 95 z28 and light is on indicating i have low coolant but its full the temp gauge occasionally goes up slowly but never hits red what should i do?
Old 10-14-2007, 10:16 PM
Default RE: coolant level low symbol need help!!!!
Have you checked the coolant to make sure its not low, if full and the light it still on its the sending unit for that sensor.
Old 10-19-2007, 01:19 AM
sewerrat's Avatar
Yep, probably the level sensor. It's located on the pass. side rad. tank. You can either replace it, or disconnect it and make sure you do periodic checks on you coolant tank (not recommended), or be lazy like me and ignore it (also not recommended).
Dana
10-29-2012 07:52 AM
Chrisd0729
09-04-2011 10:07 AM
evilbeef54
07-27-2008 09:47 PM
aleksandr
03-25-2008 01:50 PM
user 7208220
08-29-2006 07:07 PM
Quick Reply: coolant level low symbol need help!!!!
