Coolant fan question
Hi im new to the fourm.
I recently purchased a 94 Z28 with a lt1 in it.
I love the car but I cant get my fans to kick on.
I have changed my coolant sensor (on the water pump) changed my relays and also bought a Jet coolant switch in hopes that would fix it.. like anyone can install it.
so I hook up my pigtail included in the kit and ground it out, fans come on.
I can manually turn my fans on and they work.
when I ground out the pig tail my relays click and my fans come on.
I would be happy if they came on at stock temps or a shop would have any interest in doing the install, but they havent.
Please help! I want to drive the car but I am afraid of getting stuck in traffic.
thnx, stu.
thnx, stu.
did you look at this. its in the how to and faq sticky at the top of the 4th gen section.
https://camaroforums.com/forum/4th-g...ne-fans-54192/
Are you sure your temp is getting high enough for the fans to kick on?
I do remember reading somewhere that really the only time the fans kick on (other than when the water temp gets into a certain range) is if there is insufficient air flowing through the radiator. So if you're doing a lot of highway driving they won't kick on. I've taken thirty mile trips where it'd 35-60 mph the whole way and the fans would never kick on.
