coolant leak question
Old Feb 2, 2013 | 11:15 AM
Camaroboi22's Avatar
Question coolant leak question
Leaking coolant under throttle bodie sitting on edge of intake under im guessing the vaccum line? My question is were the coolant coming from if throttle body or intake?
Old Feb 2, 2013 | 11:31 AM
MKCoconuts's Avatar
If it's near the throttle body, could be one of the heater lines going to the TB. Should be one on each side of it. Check to see if they're worn out or loose.
Old Feb 2, 2013 | 11:38 AM
I put new clamps and hoses on the throttle body on both sides and still leaking. When i put pressure gauge on it it leaked worst but cant tell from were
Old Feb 2, 2013 | 11:09 PM
MKCoconuts's Avatar
What engine are we dealing with?
Old Feb 3, 2013 | 06:16 AM
what year and engine? could just bypass tb.
Old Feb 3, 2013 | 09:44 AM
I have and lt1
Old Feb 3, 2013 | 09:56 AM
could be one of the hoses going to the tb or the gasket. can do a bypass using one of these Corvette LT1 Coolant ByPass Kit : Amazon.com : Automotive or make one using pipe nipple from local hardware. heres a procedure
Throttle Body Bypass Procedure and schematic here http://www.google.com/imgres?imgurl=...ed=0CBoQ9QEwAw
djsquare1
Oct 2, 2012 11:21 AM
Disguised Manic
Apr 25, 2012 12:11 AM
mccoyj91
Mar 10, 2010 08:35 PM
bvans
May 2, 2009 12:09 PM
terelk
May 31, 2006 04:18 PM
