LT1/LT4 Tech 1993-1997
Console shift plate loose.
Old Sep 30, 2017 | 10:35 PM
cardo's Avatar
Default Console shift plate loose.
Got my console back in and everything functions (e-brake, shifter and light to). But the the shift plate pops up when I go to Park. It sits down when I put it down but the rear of it pops up when shifter goes into Park. It's like I'm missing a little plastic tab somewhere but I don't see any broken stub. Both tabs in the back are there as well as both tabs up front.
Any ideas?
Old Oct 3, 2017 | 04:33 PM
try cleaning it and use some restore stuff on it. helps to let the pieces slide.
Old Oct 7, 2017 | 05:25 PM
cardo's Avatar
Oh I cleaned it pretty good. Used something called Formula (similar to Armor All) and it slides as good as ever. Its like its missing a tab some where or maybe it has shrunk up some while the center console hasn't or at least not as much.
Old Oct 7, 2017 | 07:22 PM
went and looked, mine has three at each end. also could be the shift cable needs adjusting, shouldnt if you have not done anything with transmission.
Old Oct 8, 2017 | 11:52 AM
cardo's Avatar
Well I looked things over again and noticed the boneyard shift plate I replaced my original with has some visible differences. Also I don't recall what years of 4th Gen the junkyard console and shift plate came from.
The plastic is to slick now to use tape now that I treated it with protectant so I tried an electrical terminal lug wedged in the front of the shift plate and it holds well enough. I plan to replace that lug with tiny black zip ties (2) for ease of R&R. Really don't want to use a small wood screw as it looks too bubba though it would be hard to notice.
That should be good enough until I find a console & shift plate combo that fit correctly.
Thx.
mfmfim
Dec 12, 2013 04:52 PM
GreenMamba
Sep 1, 2012 09:21 PM
squidnut
Jan 24, 2012 10:04 AM
Cucamonga70
Mar 4, 2010 08:47 PM
