LT1/LT4 Tech 1993-1997
computer question???
Old Aug 5, 2010 | 07:52 PM
EagleRex's Avatar
what aldl cable is it? its kind of confusing
Old Aug 5, 2010 | 08:00 PM
i called to make sure i got the right stuff to do what i wanted. lol. then i had to have my daughter set up the computer cause i dont know how to use a pc. she had fun runing the car through the paces with me.
Old Aug 5, 2010 | 08:02 PM
EagleRex's Avatar
how much did you pay for yours
Old Aug 5, 2010 | 08:19 PM
Massey's Avatar
Um... forget putting the 95 Computer in the 97 car... It is not going to fit. The cables to the computer are not alike. The 95 had a unique computer. To figure out your car you only need to visit your local autopart store and have them read the codes. To have your computer reprogramed you can get a USB to OBDII cable and then you will need software that will interface with your car. I am not sure where to get the software but a simple search from google, bing or what have you will find you a cable. Last time I looked the going price was between $20-$30. Not sure on the software.
Massey
Old Aug 5, 2010 | 08:29 PM
EagleRex's Avatar
Massey
im not putting the 95 in, i already know now it dont work, i have a program, i just need the cables
Old Aug 5, 2010 | 09:22 PM
Your car seems to be ruining poorly when the PCM switches to to closed loop operation. Typically 1 to 2 minutes after starting. This usually indicates a sensor problem. Disconnect the wires from the MAF sensor, this will keep the PCM in open loop, and see if the engine now runs better. If it does, you will still need a scanner and verify that all sensors are working as they were designed to do.
Old Aug 7, 2010 | 04:27 PM
EagleRex's Avatar
i unpluged the MAF it did ok but then ran like crap, i plug it back in and it ran better but still ran rough, and idled like crap. lots of black smoke. any suggestions on what it is.
Old Aug 7, 2010 | 08:29 PM
Black smoke indicates a very rich mixture. Could be due to a misfire, bad pressure regulator, injector stuck or held open by a short to ground, clogged air filter, bad MAF, bad O2 sensors. A scan tool should help to pin the problem down.
Old Aug 7, 2010 | 08:42 PM
just to take it out of the equation test the evap system as well.
Old Aug 9, 2010 | 10:05 PM
  #20
EagleRex's Avatar
it was the damn fuel pressure regulator. but it feels great to have the z28 back to running condition.
apacheco514
Jul 22, 2011 10:24 PM
bryns81z28
Jun 10, 2011 08:16 AM
camaro1960
May 21, 2010 07:15 PM
bryns81z28
70-81 V8 Tech
Jun 30, 2009 06:31 PM
jim022659
May 8, 2009 02:02 AM
