LT1/LT4 Tech 1993-1997
coil?
Old Feb 21, 2007 | 01:24 PM
94Z28interceptor's Avatar
Default coil?
i took a 93 Z for a test drive the other day and it had a fairly noticeable miss at low rpms. the seller said he had replaced the plugs, wires, cap/rotor, and distributor. my question is how often do you hear of the coil or coil wire going bad? it is an electrical problem and thats all thats left i think. is there more or what should i try? i dont want to throw a bunch of parts at it and waste money.. thanks
Old Feb 21, 2007 | 03:52 PM
Default RE: coil?
Look at the coil and ignition module, including connectors. Stuff happens after 13 years. I would also recheck the plugs and wires & make sure they are OK. You colud also have a bad injector or some serious mechanical damage. Is the check engine lit?
Old Feb 22, 2007 | 02:19 AM
Default RE: coil?
no the check engine light isnt on.. they did a compression test on it to make sure it wasnt a bent valve or something and that was fine with 160 or so p.s.i.... and im pretty sure its not the wires or plugs with them only having a couple hundred miles on them now... butthat could still be i guess.. i thought he said he just put an ACDelco ignition module on too... i could be wrong though... it also doesnt like to start right away.. i mean when you turn the key it clicks. ill hold it for literally 10-15 seconds then it will turn over. could this be dirty terminals? bad starter? anyideas areappreciated thanks
edit: also when the car gets wet it runs VERY poorly
67Dork
Apr 7, 2011 11:39 PM
kudnu89
Jan 5, 2011 09:42 PM
carl1000
Dec 5, 2007 04:15 PM
joeyninetoes
Nov 28, 2007 09:07 AM
Anthonys00SS
Oct 10, 2007 06:18 PM
