LT1/LT4 Tech 1993-1997
code help
Old Dec 8, 2014 | 06:59 PM
CountTripula's Avatar
Default code help
ok i got tired of looking at the SES light and went to advanced auto and had them pull the codes
I have a right bank 02 sensor
P01412
P1441
P1641
If anyone knows what these are and how to fix them would be much appreciated
its a 1996 z28
Old Dec 9, 2014 | 01:50 AM
Old Dec 9, 2014 | 09:20 AM
its p0412 sorry added an extra 1 in there
what parts do i need to replace most of that stuff is latin to me sorry
Old Dec 9, 2014 | 12:06 PM
P1441 Gas tank is loosing pressure, try a new gas cap first, purge solenoid second, tank pressure sensor third, check fuel system for leaks.
P1641 Primary radiator fan not coming on, check fan relay, control wiring between relay and PCM, make sure relay is getting 12 volt from battery, check wiring from relay to fan motor, check fan motor (straight wire fan to battery & see if it turns).
P0412 AIR pump not working:
Faulty Air Pump (check fuse)
Air bypass solenoid harness is open or shorted, bad connection in solenoid circuit.
A wiring diagram for your car would be very helpful in order to check the electrical stuff.
Old Dec 9, 2014 | 05:34 PM
Ok thanks I know the fan problem the PO did a weird wireing job and took the relay out. I'll check the other stuff best I can.
kalim03
82-92 V6 Tech
Feb 7, 2010 11:56 PM
tycomps
Feb 16, 2008 09:56 PM
crusherdrivinfool
82-92 V6 Tech
Dec 16, 2007 11:12 AM
350rs
May 16, 2007 09:02 PM
dblock1989
Mar 6, 2007 08:54 AM
