LT1/LT4 Tech 1993-1997
engin bay clean up
Old Dec 12, 2014 | 08:47 PM
CountTripula's Avatar
Default engin bay clean up
ok i was wanting to take the valve covers off and clean them up and a little bit of paint on them and re paint the intake manifold its red and i want to keep it red just want to touch it up because the paint is chipping and make it look a little neater
how hard is it to do this task to take everything off and put on and what is the best paint for this application?
also is there a way to hide a few of the wires so i dont look to cluttered i dont want to a full wire tuck
Old Dec 13, 2014 | 02:46 AM
i am very happy with the powder coating on my intake. after years it still looks great. valve covers look like crab.
Old Dec 13, 2014 | 06:55 AM
There is no way to answer how hard it is. It depends too much on you and the tools you have. I have seen guys fight all day doing a water pump in an old pickup, for me its a 45 minute job.
Also you have to take into account how detailed you are and the condition of the car. I have seen guys take hours cleaning a motor and never pick up a wrench or a paint can and that is on a motor that cleaned last year.
Don't worry about heat resistant paints but don't buy generic either. Rustolem, Krylon or duplicolor are all good to over 350 degs. If your motor gets over 350 degs how well your paint condition is will not mater, the only one seeing it is the metal scraper.
Remember paint will not stick to oil or dirt so the largest part of this job is cleaning.
Old Dec 13, 2014 | 09:52 AM
Its not bad bad its just peeling off in some spots ill try to get pics in a little bit
gorn:
Im a very detailed person lol more of a perfectionist but i know that when it comes to dirt and grime elbow grease can only go so far lol.
I was talking in terms cause my 3.4 i had before i had to tare the top half of the motor off just to get to the covers and was wondering the steps for the intake manifold and valve cover removal on the z28.
I dont have my chiltons book anymore
Old Dec 13, 2014 | 12:31 PM
You have the factory manual in PDF from the manual section?
Old Dec 13, 2014 | 03:24 PM
no is there a link for it cause it sure would be helpful also is there a pdf for the chilton book?
Old Dec 13, 2014 | 04:31 PM
Old Dec 13, 2014 | 08:22 PM
Thanks a bunch
Old Dec 13, 2014 | 09:40 PM
pretty standard. i use pieces of pencel stuck in four corners of the intake to hold it up and help it to go into place when lowered. need to have it go straight as you can as you lower it so the front and rear gasket maker sets up right. i use pieces of pencil but I'm sure dowel will work. pencil fits tight and comes out pretty easy. you will want to set the intake down and mark one for length. if to long the intake holes will not line up right to lower it, too short and you its a pain to get them out once the intake is installed. cost me 100 bucks to have the intake powder coated. had it done in black.
Old Dec 14, 2014 | 09:00 AM
Now that's clean and sexy lol I'm not sure if there is place to powder coat where I'm at I live in the mountains
