LT1/LT4 Tech 1993-1997
Check engine light
Old May 29, 2010 | 04:38 PM
EagleRex's Avatar
Default Check engine light
what is the code manufacturer emission control mean? people at autozone dont know. any clue?
Old May 29, 2010 | 04:48 PM
Means that Autozone uses a cheap scanner that is not programmed to define the code it read. However, it should give the DTC number, which can then be looked up in a good service manual. OBDII has several types of codes. Generic trouble codes are defined by law, while proprietary codes, such as you indicated, are defined as the manufacturer sees fit. Many good scanners are programmed to define most proprietary codes, but it is always best to check with the FSM.
ghanahost
Feb 21, 2010 12:49 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
gozzy341
May 20, 2007 11:00 AM
airchevy02
Sep 29, 2006 06:41 PM
teamlilE1
Mar 12, 2006 02:22 AM
