LT1/LT4 Tech 1993-1997
Changing the oil
Old Aug 21, 2006 | 08:42 PM
camarorz28's Avatar
Default Changing the oil
Hey guys sorry i'm new here and new to my car i just got a 94 Z28 and well i want to change the oil on the car aperently it hasent been done. Anyways how many quarts of oil do i pore in? Another question what should i use to clean the exterior of the motor it looks really dirty, what do ya sugest.
Old Aug 21, 2006 | 10:41 PM
SickSickSick's Avatar
Default RE: Changing the oil
5 quarts if you put in a new filter. Sick
Old Aug 21, 2006 | 11:04 PM
Engine cleaning: I like to use spray Gunk. However;do NOT get the distributor wet, under any circumstance, unless you enjoy installing a new one. Optispark hates water.
Engine Oil change: FSM calls for 5W30 winter, 10w30 summer. However, if car has over 100K miles 10w40 year round may work out better. I prefer Mobil1, but any good brand name oil of the right viscosity will do fine as long as you change it, and the oil filter every 3000 miles.
Chassis lubrication. The lower ball joint have grease fittings, which are hard to see as they are hiden inside the wheels, don't forget to shoot some grease in these fittings every 3000 miles also. May have to remove the front wheels if you don't have the right shape gun.
Old Aug 22, 2006 | 02:32 AM
camarorz28's Avatar
thanks guys for your respons,
DashingDaryl
May 21, 2012 07:11 PM
jason7504
Oct 16, 2008 11:51 PM
iroc_an_87
Mar 27, 2008 10:51 AM
350rs
Jul 6, 2006 07:04 PM
mizticz28
Oct 11, 2005 01:59 AM
