Changing a cam
Old Jul 5, 2006 | 10:27 PM
350rs's Avatar
March 2008 ROTM
Default Changing a cam
im seriously concidering changing the cam in my 350 to be slightly meaner. Is this a motor out type of change? or can it stay in? what? I have an 89 RS. Its nothin to special yet, as you all know by now, but im modifying it bit by bit as the money is available.
Old Jul 5, 2006 | 10:54 PM
SickSickSick's Avatar
Default RE: Changing a cam
motor stays in. you will have to change the lifters as well. the intake and distributor has to be removed. most all the accessories a/c, alternator, power steering will have to be moved to the side. harmonic balancer, water pump, and timing chain cover has to come off. the radiator, fan, and a/c coil will have to be taken out. good luck. sick
Old Jul 5, 2006 | 11:46 PM
350rs's Avatar
March 2008 ROTM
good lord... thanks though. sounds like youve done it once... or twice.
Old Jul 6, 2006 | 03:06 AM
TimmyTheWop89's Avatar
third generations are hard to work with, no room anywhere. if it were me and i were doing a valvetrain upgrade, ide just pull the motor out, and while its out, clean up the engine bay spotless.
Old Jul 6, 2006 | 07:04 PM
350rs's Avatar
March 2008 ROTM
im not plannin on doin that though, not untill i can get a new car for a daily driver and then make this car a mean street machine.
DashingDaryl
May 21, 2012 07:11 PM
jason7504
Oct 16, 2008 11:51 PM
iroc_an_87
Mar 27, 2008 10:51 AM
camarorz28
Aug 22, 2006 02:32 AM
mizticz28
Oct 11, 2005 01:59 AM
