LT1/LT4 Tech 1993-1997
cam swap components/details
Old Jul 7, 2010 | 10:14 PM
ricer_killaZ28's Avatar
Default cam swap components/details
im still planning on getting le2 heads and the 223/230 cam, 58mm ported intake and 58mm TB. My first question is, will I need to get larger fuel injectors? if so which ones? also what length pushrods should i get? i know stock length is 7.200" but i read milling of the heads changes what length pushrods are needed.
Old Jul 8, 2010 | 01:52 AM
are you going to use 1.6 roller rockers with it? lloyd recomended i use a 37lb injector with 1.6 rr. i am now using 30 lb red tops. am thinking of switching to ford 32lb ones that will flow between 30 and 36 depending on where i set the fuel pressure. you can measure to find the proper length for pushrods. https://camaroforums.com/forum/93-02-general-41/measuring-checking-push-rod-length-51829/
Old Jul 8, 2010 | 02:11 AM
yeah I'll get 1.6rr's. so it just sounds like injectors in the mid 30s should be fine then?
Old Jul 8, 2010 | 08:10 AM
whammer3024's Avatar
ROTM Winner
if you're getting LE2 heads, lloyd would be the main guy i'd be talking to about other parts he suggests. it is kind of his job and all
jim64123
Mar 29, 2013 10:46 AM
silver97
May 12, 2011 07:09 PM
coastie kyle
Sep 13, 2009 09:49 AM
keith_AE2010
Jul 25, 2008 08:42 AM
Lee Willis
Dec 3, 2005 11:44 PM
