LT1/LT4 Tech 1993-1997
Cam question
Old Jun 15, 2006 | 12:22 AM
97F1's Avatar
Default Cam question
I have a 97 F1 and I'm considering buying an aftermarket cam for my car. I'm looking for one with noticeable sound at idle but hopefully possible on finding one which doesnt totally trash the gas mileage. Also I'm curious as to whether or not I have to pull the whole block out considering its halfway under the firewall and also whether or not I'm going to have vacuum or electrical "shortages" if you will. You guys have any suggestions?
Old Jun 15, 2006 | 11:27 PM
Default RE: Cam question
To change the cam,you need to remove the intake manifold and make room in front of the engine. You will have plenty of room by removing the fans & radiator, and the manifold can be romeved without too much of a hassle. As for cams, everyone has a different opinion, so the best bet is to talk to a cam grinder.
Old Jun 22, 2006 | 10:55 PM
97F1's Avatar
thanks a bunch!
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
