LT1/LT4 Tech 1993-1997
Cam question
Old Jul 20, 2009 | 07:42 PM
Blk93Z28's Avatar
Default Cam question
I'm curious to what the max valve lift is on stock LT1 heads, or would that be determined by the stock springs. I have the iron heads from a caprice on mine, which i don't care for though. But anyway, how far can you go with a cam?
Old Jul 20, 2009 | 11:09 PM
i think the 93 has a 460 lift with longer springs stock so to change to something thats going to be noticeable will require better springs.
Old Jul 21, 2009 | 09:13 AM
whammer3024's Avatar
ROTM Winner
stock springs can only handle the stock cam. just putting in better springs and 1.6 rockers will increase your horsepower. but new springs are a must when doing a cam swap
Old Jul 23, 2009 | 06:26 AM
Blk93Z28's Avatar
OK thanks. I'm thinking about atleast a .550 lift so I'm trying to figure out what all i'll need. Gonna get some parts together and hopefully start on it in the next couple of months. Any ideas on some cheap heads until I can afford some really good ones? I don't want to use the iron ones.
Old Jul 23, 2009 | 10:14 AM
Saint_Ali's Avatar
theres a sticky in the lt1 section i made for cam swaps.there is no such thing as cheap heads,theyre all pretty expensive lol
Old Jul 23, 2009 | 01:25 PM
ROTM Winner
^^^speaks the truth there. just get some aluminum heads off of a camaro and call it a day if you don't want the iron heads
Old Jul 23, 2009 | 07:23 PM
Blk93Z28's Avatar
Lol thanks guys
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
