LT1/LT4 Tech 1993-1997
A/C problem
Old Nov 2, 2009 | 09:28 AM
A Stinky Bumb's Avatar
ive heard that it takes some power to spin the ac and if ya take it out and put in just a free moving pully the engine doesnt have to work that little bit so you get a little extra horse power... any one got pics of how to do this?
Old Nov 2, 2009 | 01:18 PM
dopez28's Avatar
well that is true, if the a/c is on. ya could do a drive around test to see, and ya can feel the difference.
Old Nov 3, 2009 | 10:14 AM
well it still screaches whether or not the a/c is on and i dont want it to lock up... i just want it out!
Old Nov 3, 2009 | 10:58 AM
CNCman's Avatar
One note: if you do remove it, try to plug everything, clean all the parts, and store them in a bag/box. You may want to put them back or sell them.
Old Nov 3, 2009 | 02:15 PM
sm515's Avatar
in 1320 feet (quarter mile) one hundred pounds is about a tenth of a second in elapsed time. which is about a car length. 20 pounds (ur a/c) would be 2 hundreds of a second. 2 hundreds is more than a bumper at the finish line. races are won by thousands everyday...i'd take it off. then again i'd wish it was on there everyday in july/aug. also take it a couple steps further, if ya could find 5x20 pound objects that would make your 13.09 a 12.99.
Old Nov 3, 2009 | 06:47 PM
i wasnt really plannin on keapin it cause its going bad... i would just go out back and throw it on a 5 foot high scrap metal pile...
sm15: that is an awsome analogy and im with ya because of that reason too i want to lighten the car as much as possible while doing work to it. however it does get slightly hot in ohio durring those months but thats why they invented T-Tops
Old Nov 5, 2009 | 02:42 AM
95slvrZ28's Avatar
The A/C only uses power when you have the A/C on or the Defogger on, otherwise the clutch is not engaged and the pulley acts as an idler pulley. If you use Pete's method you will never be able to actuate the solenoid that engages the clutch, and therefore no matter what climate setting you choose, the A/C cannot engage.
If you're hell bent on removing it for weight savings I highly recommend you start removing sound insulation as well as any extra seats, speakers, carpeting, door cards, interior trim etc.
Old Nov 5, 2009 | 09:40 AM
alright im not really hell bent on weight removing but why not get rid of something that doesnt work and isnt neaded... i mean it cant hurt... but how much weight does a back seat delete drop? how much does those back seats wheigh?
Old Nov 6, 2009 | 01:35 AM
95slvrZ28's Avatar
I just personally think that it will be more trouble than it's worth, but I've already stated that.
Removing the rear seat can probably save you about 20lbs. Same with the stereo equipment, speakers and amps are heavy.
Old Nov 6, 2009 | 01:36 PM
  #20
alright... is there a list of stage wheight drops on this forum? like 1st stage obvious stuff that can be done in any normal garage stage 2 some knowledge of parts and stuff and like a 3rd complete drag car wheight drop?
