LT1/LT4 Tech 1993-1997
bose system
Old Jun 28, 2011 | 02:07 PM
Dice276's Avatar
Default bose system
I just got a '93 Z28 a few weeks ago with the bose sound system in it and im wondering where i can get the adapter to make an aftermarket headunit work with it.
Old Jun 29, 2011 | 01:30 AM
Knightrider03m's Avatar
I bought mine at Mejier
Old Jun 29, 2011 | 12:53 PM
Dice276's Avatar
well what is it called cause i tried to get it from best buy and they gave me the wrong thing
Old Jun 29, 2011 | 06:10 PM
WIspartan1026's Avatar
May 2013 ROTM
I think it's called a "factory amp interface"
Old Jun 30, 2011 | 07:40 PM
s_m_a38@yahoo.com's Avatar
Had the same problem and did some research and so far I've found two options you can do.
1) Go out and buy new speakers and just wire them straight from the HU to the speaker. This is what I did because I plan on adding rear speakers (mine was only optioned with the two door speakers and the sub) along with amps and two 12" subs.
or
2.) Go out to your local Walmart, or ebay, or another auto electronics store and find the Scosche Fai-3a, it should be a blue rectangular device. This converts the signal properly and allows you to keep your stock speakers.
Option 1 is more expensive, but if you plan on putting aftermarket speakers, subs and amps, to me it makes more sense and is easier. But if you plan on keeping the original speakers and sub, then option 2 is your cheaper and more sensible method. Just all depends on what you're going to do.
Pig Hunter
Oct 16, 2017 08:15 PM
305_camaro
Jul 22, 2011 10:41 PM
hoursetraitor
Dec 26, 2010 05:11 PM
osduck5
Nov 1, 2010 05:14 PM
thecrowe14
Jul 28, 2005 12:41 AM
