LT1/LT4 Tech 1993-1997
bolts
Old Dec 13, 2006 | 05:50 PM
carguylt1's Avatar
Default bolts
I have to rebuild the bottom end do I need to replace the rod and main bolts? Do I use bolts for a regular 350 of are they like most parts and to made specificaly for the LT1? I have been told when you pull the heads to change the head bolts should I, and do I need a special set just for the LT1?
Old Dec 13, 2006 | 11:33 PM
shnormo's Avatar
Default RE: bolts
It is recomended to use new bolts. I'd go with ARP designed for your application. Your motor has 2 side main cap bolts, essentially making it a 6 bolt main. So a regular 350 kit won't give you all the bolts needed. With cheap customers, we put the old bolts back in. But then again it's cheap insurance.
Old Dec 13, 2006 | 11:39 PM
shnormo's Avatar
Default RE: bolts
070-234-5608 Chevrolet LS1, LS6 5.7L & 6.0L
4-Bolt Main $174.99 at Jegs.com
070-134-6403 Chevy 350 Wave-Loc, 3/8' $54.99
Old Dec 14, 2006 | 01:38 AM
Default RE: bolts
You definetely have to replace the head bolts if you remove them, they are torque to yeild bolts and can only be used once.
Old Dec 14, 2006 | 04:59 PM
carguylt1's Avatar
Default RE: bolts
LT1 not LS1 there is a little difference there.
ORIGINAL: shnormo
Old Dec 14, 2006 | 09:42 PM
shnormo's Avatar
Default RE: bolts
My mistake.
Phalen123
May 12, 2011 12:40 AM
endo
Sep 19, 2010 11:25 PM
z28rob18
Mar 12, 2010 09:15 AM
vinnyboombots
Mar 28, 2009 10:53 PM
awake1630
Apr 2, 2008 11:04 AM
