bolt on mods
RE: bolt on mods
i think tht you should do full exhaust headers, intake, underdrive pullys and if you have a little extra cash left over buy a cam because all tht flow isnt going to do much unless you put some more lift on those valves and you have to do springs too.
RE: bolt on mods
Under drive pullies are pretty close to a useless mod on a 4th gen. The only thing the belt drives is your water pump, alternator and your A/C when you have it on. You're better off getting an electric water pump than the under drive pullies, that way your A/C works and you don't risk running into issues with your battery not charging as it should because your alternator isn't spinning fast enough.
RE: bolt on mods
im 18 too can i have a prize?like everybody said already exhaust is one of the first mods to do.. but if your looking for cheap power nitrous is #1 for some real power for not much money. just dont over do it on a stock engine and get a wet system if you choose too.
RE: bolt on mods
ORIGINAL: 95slvrZ28
remember , an engine is a big air pump. the more air you can get in and out , the better it will preform. start with a nice cold air kit , some decent headers and full exhaust , your $1500 is pretty much gone then , but you will feel a noticeable gain in power and get better fuel mileage to boot.
RE: bolt on mods
ORIGINAL: Spartan66
I read in Camaro Performers that you can use a smaller underdriven pulley to create more boost... but that was installed with a Vortec S-Trim charger.
#20
RE: bolt on mods
thanks for all you help. i think i am going to buy a $300 leaf blower and hook it up to my intake and boom right there like 8lbs of boost. ya i am kidding about all the but still thanks for all your help. if i where to do all boltons intake and exhaust eletric water pump around how much hp can somone get with just external work. i am 18 too yaaaaaa lol.
