LT1/LT4 Tech 1993-1997
Bolt broke flush at top of water pump.....
Old Aug 15, 2014 | 05:16 PM
mrfreez's Avatar
Default Bolt broke flush at top of water pump.....
Does anyone have any tricks to getting a bolt out that broke flush at the top of the water pump? I was changing the thermostat and putting the housing back. When I was tightening one of the bolts it broke flush in the water pump. I haven't had luck with drilling out bolts before but I'll try it again if I have no other choice. Hopefully someone with more experience than me has some sweet tricks!
Old Aug 15, 2014 | 06:31 PM
Take a sharp center punch, rap on it with a hammer off center on the bolt end, and use the hammer to hit the bolt counterclockwise.
Old Aug 15, 2014 | 10:18 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Or just use an extractor bit. It might be easier since it snapped flush
Old Aug 16, 2014 | 08:41 AM
mrfreez's Avatar
Let me know if this is a good idea... here's what I'm going to try:
1. Center punch to start hole.
2. Small drill bit and drill half way drilling counter clockwise
3. if bolt doesn't come out, use slightly larger drill bit
4. Tap in easy out and attempt to get bolt out.
Old Aug 16, 2014 | 09:35 AM
First try tapping it out with the punch, that way works great if the bolt isn't frozen into the hole. Not likely to work when the bolt snaps off when trying to remove it because it's locked in, but you probably horsed the bolt on too hard which snapped it, not because it's stuck.
Old Aug 17, 2014 | 10:43 AM
mrfreez's Avatar
You are 100% correct. The bolt snapped when I was tightening it. Old bolt so the stress caused it to break. It broke before 10 foot pounds.
Old Aug 17, 2014 | 02:10 PM
mrfreez's Avatar
As luck would have it, the extractor broke in the hole I drilled!!! So, now I'm drilling size up and up until it's out and I'll re-tap it. ugh!
Old Aug 18, 2014 | 02:42 PM
mrfreez's Avatar
I quickly realized that there was no way I was easily getting this bolt out with the extractor broken inside it too:
So, I used the carving head of my dremel tool and carved around the area where the bolt was lodged. Eventually I pulled it out with vice grips.
I prepped the area. Since I didn't have a blow gun, a can of Dust Off worked great to clear the area of the aluminum filings. Now I'm stuck with a big hole. What do I do???
Permatec cold weld to the rescue! I've used this stuff before and it's awesome! JB Weld is garbage and doesn't work so don't waste your money!!!
I put the epoxy in a paper plate:
Then I mixed it. You have about 10mins to work with it before it starts to harden:
I filled the large hole with the metal epoxy. There are quicker drying ones on the market... don't buy them! Buy the regular stuff that takes overnight to dry and harden! You'll be glad you did! Once it's hardened I will sand it down to be flush so the housing seats properly. Then I'll tap a new hole!
Old Sep 3, 2014 | 07:56 PM
mrfreez's Avatar
Just an update to put closure to this thread... I replaced the water pump and thermostat housing.
BlackBerlinetta
82-92 V8 Tech
Aug 18, 2012 09:00 AM
chevyman510
Apr 19, 2012 05:22 PM
frostlime69
67-69 V8 Tech
16
Nov 9, 2008 09:20 PM
Slick6
Apr 1, 2008 10:46 AM
superROB23
Oct 12, 2006 11:36 AM
