been fighting this power drain for 8 months
#21
woh,,, got em. sure looks like a mess, much bigger pictures here. i would advise you pick up a factory service manual for you year. sometimes you can get a set for cheap on ebab a cragsliste
![Name: 1311731584.jpg
Size: 70.0 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/24943d1501303703-been-fighting-power-drain-8-months-1311731584.jpg)
![Name: 1311351224.jpg
Size: 76.0 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/24944d1501303703-been-fighting-power-drain-8-months-1311351224.jpg)
![Name: 1311351222.jpg
Size: 48.5 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/24945d1501303703-been-fighting-power-drain-8-months-1311351222.jpg)
![Name: 1311351217.jpg
Size: 82.3 KB](https://camaroforums.com/forum/attachments/lt1-lt4-tech-9/24946d1501303703-been-fighting-power-drain-8-months-1311351217.jpg)
#22
Wow, that is some messed up wiring. Yeah, I would listen to Craby, get the manual, and disconnect all of that alarm stuff. VATS works well enough to deter 90% of car thiefs...
Good luck and kill Rustanks!!!
x01660
x01660
#24
Good news! Everything is removed and thank gawd the used jumper splices
But they spliced into stiuff that wasn't working or flashing like my ses wire!
The bad. Yeah but it is minor. The security flashes every now and again but as soon as I push in key a little it stops and shuts off but I atleast I'm moving foward
#25
Hey can I add these two questions so I'm not cluttering this place up?
First? What cause the right turn indicator arrow to illumnate when I turn the headlight switch on?
I replaced the turn signal switch and blinker relay would this be a bulb which all work btw or the headlight switch? Yeah bizzar lol
Second if my passenger window goes up slow is it a sign of the motor going out ?
#26
With the window, often times it's due to the inefficient pass. side window wiring setup the car has. It's so common, they make a fix for it: AutoTrix :: Passenger Window Fix Kit
#27
4th Gen LT1 F-Body Tech Aids
Its like 1/4 of the way down. You should actually probably bookmark that page. It has a lot of good info.
x01660
#29
If you want to go this route, I'd get the kit, or buy everything that's in it. You don't want to mess with your electrical system... There is also a writeup on Shbox on how to do it...
x01660
x01660
