LT1/LT4 Tech 1993-1997
been fighting this power drain for 8 months
Old Jul 27, 2011 | 12:11 AM
  #21
woh,,, got em. sure looks like a mess, much bigger pictures here. i would advise you pick up a factory service manual for you year. sometimes you can get a set for cheap on ebab a cragsliste
Old Jul 27, 2011 | 12:20 AM
  #22
x01660's Avatar
The Mustang Hunter
Wow, that is some messed up wiring. Yeah, I would listen to Craby, get the manual, and disconnect all of that alarm stuff. VATS works well enough to deter 90% of car thiefs...
Good luck and kill Rustanks!!!
x01660
Old Jul 27, 2011 | 08:04 AM
  #23
grabbem88's Avatar
I only got a haynes manual. I guess I need more considering the mess that craby blew up for me lol
Old Jul 27, 2011 | 11:19 AM
  #24
grabbem88's Avatar
Good news! Everything is removed and thank gawd the used jumper splices
But they spliced into stiuff that wasn't working or flashing like my ses wire!
The bad. Yeah but it is minor. The security flashes every now and again but as soon as I push in key a little it stops and shuts off but I atleast I'm moving foward
Old Jul 27, 2011 | 01:26 PM
  #25
grabbem88's Avatar
Hey can I add these two questions so I'm not cluttering this place up?
First? What cause the right turn indicator arrow to illumnate when I turn the headlight switch on?
I replaced the turn signal switch and blinker relay would this be a bulb which all work btw or the headlight switch? Yeah bizzar lol
Second if my passenger window goes up slow is it a sign of the motor going out ?
Old Jul 27, 2011 | 03:23 PM
  #26
First: that's usually a sign of a bad ground somewhere. With a poor ground, power will try to feedback into anywhere it can to find ground. When that happens, it will give some power to that circuit. Check and make sure you didn't knock/break anything off under the dash.
With the window, often times it's due to the inefficient pass. side window wiring setup the car has. It's so common, they make a fix for it: AutoTrix :: Passenger Window Fix Kit
Old Jul 27, 2011 | 03:42 PM
  #27
x01660's Avatar
The Mustang Hunter
Good stuff man! Now, the next thing you might want to do (and this is really dependent on where you live) is disable VATS. You can find a writeup here:
4th Gen LT1 F-Body Tech Aids
Its like 1/4 of the way down. You should actually probably bookmark that page. It has a lot of good info.
x01660
Old Jul 27, 2011 | 05:44 PM
  #28
grabbem88's Avatar
This autotrix looks simple enough
Can two 5 amp relays work just the same
Old Jul 27, 2011 | 05:49 PM
  #29
x01660's Avatar
The Mustang Hunter
If you want to go this route, I'd get the kit, or buy everything that's in it. You don't want to mess with your electrical system... There is also a writeup on Shbox on how to do it...
x01660
Old Jul 27, 2011 | 06:01 PM
  #30
Psycho's Avatar
I believe you have a bulb that is bad or a bad connection on the side that the turn signal is indicating. Check the bulb sockets for rust or corrosion if the bulb is not lighting.
