LT1/LT4 Tech 1993-1997
been fighting this power drain for 8 months
Old Jul 26, 2011 | 07:53 PM
Grandpaswagon's Avatar
I would bet that it is the alarm that was causing the problem. You can check it by putting the fuses and lights back in.
When taking out the alarm, just trace the wires back one at a time. I believe that the starter interrupt will be a purple wire that will be in the main harness under the dash. At least, that was what it was on mine. I just removed the alarm and spliced the two purple wires together and everything else worked fine.
Old Jul 26, 2011 | 08:31 PM
grabbem88's Avatar
So what I gather the camaro's did not have a factory alarm as well? The clear box you
Can see the circuit boards a red/green flashing light and some sensitivity setting
I'm gonna try again posting pics
Old Jul 26, 2011 | 08:51 PM
x01660's Avatar
The Mustang Hunter
Another option you could try (though tedious) is to get a multimeter, switch over to amperage, then go one by one, disconnect all of the fuses and relays and connect the multimeter in series, and see if there is draw. If the car is off with the keys out of the ignition, and you find draw on a fuse, that's where in the wiring your drain is. Then you get to have fun and trace it down...
Good luck and kill Rustanks!!!
x01660
Old Jul 26, 2011 | 08:57 PM
grabbem88's Avatar
Old Jul 26, 2011 | 09:04 PM
x01660's Avatar
The Mustang Hunter
1. Good pics, but they are really small, and you can't see detail. Any way you can take them with an actual camera and upload them so we can see?
2. Your best bet would be to just remove the darn alarm. Unless you really want it. As it is, 4th gen F-bodies aren't the hardest vehicle to break into. Ask me why I know this...
x01660
grabbem88's Avatar
Just scroll through the pics. I finally figured it out
@xo1660 the last rustank I owned ran 10.26 at 136mph then it fell apart lol
Just jabb'n I just have love for both lol
Old Jul 26, 2011 | 09:06 PM
grabbem88's Avatar
Figures since you have a computer and I'm using the. Magnify glass on my phone to
Blow them up
Old Jul 26, 2011 | 09:15 PM
x01660's Avatar
The Mustang Hunter
You said you figured out what the problem was. Is one of the connections grounded?
x01660
Old Jul 26, 2011 | 09:21 PM
grabbem88's Avatar
Lol no no the photobucket issue
As to the pics I like to know if anybody has seen that green box in a factory car?
I believe ya on breaking in these cars
Old Jul 26, 2011 | 09:36 PM
  #20
x01660's Avatar
The Mustang Hunter
That box is not there. It's aftermarket. Your best bet will be to just remove it and if you want, reinstall it properly. Electrical gremlins suck...
x01660
