LT1/LT4 Tech 1993-1997
BB in a 94z?
Old Nov 30, 2006 | 08:55 AM
phoenixpit's Avatar
Default BB in a 94z?
I just purchased a 94 z28. It is a roller with a 8 point roll cage. I have a 454 BB that used to be in my 68 camaro race car. I would like to place this motor into the 94. Is there a way I could do this other than changing the front chassis to a 67-69 Camaro front? Thanks
Old Dec 3, 2006 | 01:40 PM
uncle bill's Avatar
Default RE: BB in a 94z?
Alot of Mods to make it work. Not for the meek. A '67-'69 subframe is out of the question. Call a Race Chassis shop and get it done.
Old Dec 3, 2006 | 02:24 PM
JD1969's Avatar
It's not as bad as Bill is making it out to be. A tube K member will make it pretty easy. You will need a different hood (or be a red neck and chop hole in the stocker[:'(]) and you will need to rim out the cowl area if you go carbed.
