LT1/LT4 Tech 1993-1997
Battery or Something Worse
Old Jan 26, 2010 | 10:35 PM
gagger84's Avatar
Default Battery or Something Worse
Alright, so I need some insight. I live in MN so I currently have my car in storage for the winter, but I like to go out there every once in a while and run it for a bit.
Well I have had an issue the past 2 times I've return from trips; it won't start. The first time this occurred it was pretty cold out, but I went to turn the key and all the car did was made some "clicking" sound. After a day past, my car was completely dead (no lights would work and no clicking sound) so I thought it was the battery. I connected it to a battery charger, let it sit for a few hours and then it had no problem starting up. Well the same thing happened again, but I can't get it started this time.
I currently have it connected to the charger again, but it just won't turn over. Do you think its the battery or something like the alternator? And how big effect does the cold weather have on it?
Thanks
Old Jan 26, 2010 | 11:10 PM
JordanT's Avatar
I just had that happen to my car. I just finished rebuilding my engine and it just clicked and barely rolled over. I was worried something was wrong. But I got a new battery and all is good again. The other battery just had a dead cell that made it not have enough power. I would definitely take the battery in to get tested and probably just get another one. I live in Michigan and here batteries always start dying once it gets cold out.
Old Jan 27, 2010 | 03:53 AM
maudyZ28's Avatar
its the battery, im in Spain at moment but home soon, but i went home for christmas after leaving car stood for 4 months and my dad turning it over sometimes and it just clicked. It will need a full days charge and a good drive to get it working again fine
Old Jan 27, 2010 | 05:10 AM
Get a new battery and if you are going to store the car you want to find a battery tender. It basicly a small automatic charger that keeps your battery from failing because of sitting.
Old Jan 27, 2010 | 08:10 AM
whammer3024's Avatar
ROTM Winner
yeah i pulled my battery out of my car for that exact reason
also, if your car sits in extreme cold for any period of time without being started, batteries CAN and WILL freeze and good luck bringing them back to life after that.
i suggest getting a new battery and either getting a battery tender like gorn suggested or just pulling the battery out
Old Jan 27, 2010 | 09:04 AM
gagger84's Avatar
What kind of battery tenders do you guys recommend? Also, what is the proper way to store it during the winter? If I pull the battery, will the LT1 be fine after sitting for 3 months without running? Thanks.
Old Jan 27, 2010 | 11:54 AM
ESPxCONxXx's Avatar
yes, you car will be fine, just keep the battery in doors, i leave my battary in my car, throught the winter but i make sure i start it either every week, or every other week. i live in connecticut, and its gets cold here, but im tihnking im needing a new battary in the spring.
shinwolf14
Sep 1, 2009 05:41 PM
adirtypoostick
82-92 V8 Tech
15
Mar 1, 2009 08:15 PM
