LT1/LT4 Tech 1993-1997
Alternator causing rough running?
Old Oct 25, 2006 | 03:01 PM
Beninarkansas's Avatar
Default Alternator causing rough running?
97 Z28, Idles fine. Runs rough. Read codes: AIR malfunction (I removed AIR system so DUH!)
THe other code was, in effect: Alternator malfunction causing PCM problems. It charges between 13-14 volts by the guage. Anyone else had an alternator bad causing car to run like crap. P.S. New Platnium plugs and 8mm Taylor wires, cats gutted, seafoamed, throttle body cleaned.
Old Oct 25, 2006 | 03:11 PM
SickSickSick's Avatar
Default RE: Alternator causing rough running?
need to put a voltmeter on it and find out for sure. thats a little low and if you get under voltage during high load operation it could cause all sorts of running problems. Sick
Old Oct 25, 2006 | 03:39 PM
shnormo's Avatar
Possibly a bad diode. Murrays and Autozone do charging system tests.
Old Oct 25, 2006 | 09:44 PM
Low voltage will confuse the PCM and the engine, and sometimes the gages will act weird. A shorted alternator diode, generates a lot of electrical noise in addition to low voltage, further confusing the PCM, while a blown diode will only result in low voltage under load.
csmiddy
67-69 V8 Tech
Dec 9, 2012 10:12 PM
Z28Freak
May 1, 2011 10:53 PM
kc9nvw
Sep 9, 2010 04:01 PM
BasicConcepts
May 8, 2010 01:51 AM
johnson
Feb 6, 2008 12:20 AM
