LT1/LT4 Tech 1993-1997
ac r12 or 134a
Old Jun 7, 2008 | 01:10 PM
TEXASMAN1's Avatar
Default ac r12 or 134a
do yall know what kindwas in 93 z28s?
Old Jun 7, 2008 | 10:43 PM
Default RE: ac r12 or 134a
The 93 still used R12. However; you can save a lot of money by using R12 substitutes such as Freeze12, which costs about the same as R134a, and does not require any modifications or oil change to the AC system.
Old Jun 8, 2008 | 01:09 AM
TEXASMAN1's Avatar
are you 100% sure? cuz i put a bottle of 134a in it. helped a lil. i thought i needed more cuz it finish a 8oz bottle
Old Jun 10, 2008 | 03:09 PM
sl1foru's Avatar
i have a 1993 z28 i put r134 in mines an it worked fine.
Old Jun 10, 2008 | 03:19 PM
blackz87's Avatar
All 4th gen cars had r134 A/C systems.
Old Jun 26, 2008 | 01:50 PM
LT1RUNNER's Avatar
I think you may be wrong. If I remember right the R134a was not standard in cars until 95-96. Besides the R12 is way colder!!
Old Jun 26, 2008 | 02:39 PM
blackz87's Avatar
Old Jun 26, 2008 | 03:16 PM
Should be easy to figure out. If you had a recharge kit for 134a, it wouldn't fit on an R12 system. The schrader valves are different sizes between the two so that one can't be accidentally put into the other. There also should be a sticker somewhere under the hood indicating which one the car has.
Old Jun 26, 2008 | 04:54 PM
hascet's Avatar
Mine says what it takes under the hood on the sticker by the accessory belt pattern. I have a '94 z28 and it takes R134A
Old Jun 27, 2008 | 01:50 PM
aightball87's Avatar
my 94 says the same
