LT1/LT4 Tech 1993-1997
ac delete
Old Mar 25, 2010 | 02:11 PM
camaro_junky24's Avatar
Default ac delete
so i know i can get a kit for an a/c delete but what all has to come out of the car other then the compressor and all the lines and is anything going to stop working because the a/c ist there? and is it worth the effort to remove?
Old Mar 25, 2010 | 03:35 PM
not really. u gain maybe a couple hp (same if u dont turn on the ac) and dont lose much weight.
Old Mar 25, 2010 | 04:27 PM
Why do you wanna do that anyhoo?
Old Mar 25, 2010 | 08:25 PM
dont need it i dont use it thats what windows are for and i would remove for the room not the weight or the hp gain i can get the same gain from an under drive pully set
Old Mar 25, 2010 | 08:58 PM
Grandpaswagon's Avatar
Really it will only give you a little more room. The underhood layout is pretty tight in these rides, and removing the A/C will only hurt a potential resale value down the road.
Unless you have something that you want to intall in the same place as the condensor or other parts, you are just wasting time IMHO.
Old Mar 26, 2010 | 04:04 PM
myblackz28's Avatar
imo weight is weight, expecially if its on the front of the car although it dont make much difference it could be that quarter of a car length that wins the race unlikely but if you never use ac like me then y have it! i plan to remove mine just not gunna go through the trouble till i pull the engine next winter
mike6208
Jan 22, 2012 08:52 PM
skinut
Jan 4, 2012 05:50 PM
Yooper Z28
Jan 1, 2012 12:45 PM
wthile
Apr 14, 2008 08:45 PM
DRI_Z28
Jul 12, 2006 01:18 PM
