Abs Inop
I really hope this helps you guys I mean I was just foolin around with it and stumbled on it. I was aggravated not that I like ABS just want my car and the options on it to work I am a little **** that way. Mines a Garage queen gets waxed once a year
i would like some pics having the same problem with mine also my speedometor dont work car dies every time i hook it up done replaced the relay fuses, speed sensor, transmission the other day someone told me it was the bcm behind the dash i took the glove box out and found another relay fuse for the electronic brake control it was bad think that could be my problem?
Sorry to get take so long to get back with u ? Keelie. Our speedos were working. Have you tried o check the wheel speed sensor? I had an issue with mine a few years back caused the speedo to act goofy. But, didn't cause the symptoms you described. If you can pull the code I may be able to help if you have the code. The pics are posted here in his thread on photobucket. Hope this helps.
