LT1/LT4 Tech 1993-1997
97 Z28 fuel system tech???
Old Jul 22, 2009 | 12:41 PM
SGB's Avatar
SGB
Default 97 Z28 fuel system tech???
Hello out there in Camaroland!
I have a 97 LT1 that has quit on me. Long story short, it appears to be fuel system electrical related, and not the pump (thankfully). Does anyone have prior experience and/or advice on the best way to TS this problem?
What I know at this point is that the pump will prime when the key is ON, but does not run when you crank the engine.
Thansk in advance,
SGB
Old Jul 22, 2009 | 12:53 PM
more info. what leads u to say its the fuel system? gettin good spark? dry spark plugs? a good start would be to see if it has some trouble codes stored and do a fuel pressure test on it.
Old Jul 22, 2009 | 03:49 PM
If the engine does not fire within 5 seconds of cranking, the PCM will shut down the fuel pump to prevent flooding. Follow craby's advice before messing with the fuel injection. Like any other engine it needs a good spark at the plugs and at the proper time.
If ignition is OK then start playing wit the fuel system. Check fuel pressure, make sure the FI fuses are good, get some cheap NOID lites and see if the injectors are being fired.
Old Jul 23, 2009 | 11:24 AM
SGB's Avatar
SGB
the car will start, and run for a few seconds and then die presumably due to loss of fuel pressure because the pump is not running past initial prime. At the start of this mess, I had a local shop look at the car, and they believed that the problem was fuel related because they were able to get the car started by "cheating" fuel to it. Not sure exactly how they did this, but that's what I'm going on at the moment. I geuss my next step will be to get an OBD II scanner and dump the PCM codes and go from there. any idea where I can get a schematic of the fuel system?
SGB
Old Jul 23, 2009 | 08:13 PM
rondavis's Avatar
a chlitons manual will have the electrical schematic
Old Jul 27, 2009 | 08:49 AM
SGB's Avatar
SGB
Thanks rondavis, found the shematic. Now the plot thickens. The current status is that what I thought was a chronic no-start problem now appears to be intermittent. The car will in fact start about 50% of the time. The ODB 2 code is P0300 (misfire detected) which makes sense, but there are no other codes stored. Over the weekend, I was able to start cold, run up to operating temp, shut down, and re-start 5 times in sucession. Tried the same 24 hours later, and no joy. The car is sitting because I don't trust it to drive it, but it has over 1/2 tank of gas. At the monent, I am at a loss but I'm starting to think ECM/PCM. Has anyone else out there had this issue? I miss the old days when the average Joe could actually work out a problem like this without being an EE....
Old Jul 27, 2009 | 10:06 AM
ignition modual
Old Jul 27, 2009 | 10:15 AM
ChrisKJXN's Avatar
I've had a similar problem before, but it turned out to be a bad tank or two of gas. Has the car been doing this for a while or just within the past few tanks of gas?
Old Jul 27, 2009 | 12:33 PM
rondavis's Avatar
im with craby i think its the ign module its a cheap fix you local AZ should have them in stock
Old Jul 27, 2009 | 12:43 PM
SGB's Avatar
SGB
Thanks Guys! I will check out the ign mod.
Chris, the whole saga started a few weeks ago when the engine simply died while driving under normal driving conditions, and would not restart. Same tank of gas.
Since then it will start....sometimes.....can u say Gremlins?
Scott
