LT1/LT4 Tech 1993-1997
96 383 stroker HELP!!!!
Old Aug 1, 2011 | 11:07 PM
  #21
does jegs have a warrenty on there opit? we have a site sponsor on here that sells a lifetime warrented opti for under 200 bucks. (chandlermotorsports) on the other hand i use a msd and have a gm performance as a backup. summit used to warrenty there gm performance for a year and the msd opti's for two years not completely sure if they still do.
Old Aug 2, 2011 | 09:57 AM
  #22
Psycho's Avatar
Like they said, MEASURE the fuel pressure, and drop with vacuum applied to the regulator. Make sure it MEETS the specs. If it does then it is electrical. You can then check the Opti signals and go from there.
Old Aug 4, 2011 | 04:49 PM
  #23
maddog1415's Avatar
Well 12 hours later and a msd opti spark and alot of ciggs haha the opti is replaced and the car seems to be running as good as ever!! Thankyou so much everyone for all the help!
Old Aug 6, 2011 | 11:11 AM
  #24
maddog1415's Avatar
Ok so another problem has appeared the car has a hard time starting I get gas and spark and im sure it is getting air but it doesn't seem to want to strt any ideas?
Old Aug 21, 2011 | 12:10 AM
  #25
noz's Avatar
noz
check fuel pressure ...last time i ran into this problem on my msd opti the rotor bolts were loose the rotor bolts come coated with thread locked and if you removed them you have to replaced them.
Old Aug 21, 2011 | 06:21 PM
  #26
maddog1415's Avatar
problem is fixed they sent me a bad opti again freaking jegs how dare they but I got a replacement and all is well the car is running tip top now thankyou everyone for all the help!!!
italiafutbol07
Jan 6, 2011 06:31 PM
Sodamhot
Oct 3, 2009 10:05 AM
morphine51
70-81 V8 Tech
Feb 25, 2009 09:26 AM
buckfever
Dec 15, 2007 10:25 PM
travis t
Oct 29, 2007 07:48 AM
