LT1/LT4 Tech 1993-1997
95 Z28 rearend
Old 02-04-2013, 07:49 PM
richmond are good gears but loud.
Old 02-04-2013, 08:36 PM
numskull223's Avatar
Have ever installed a set in a camaro rear? Ive done 1 rearend in my old s10 and i didnt have to shim it...i ended up useing the factory shims in the factory places...Is that normal or did i get lucky?
Old 02-04-2013, 08:41 PM
Greg08's Avatar
Originally Posted by Grandpaswagon
I am fairly certain that all of the rear ends out of the Z28s are disc and posi. There are different gearing options depending on whether it came out of an auto or manual car though. I also believe that there are differences between the ABS sensor between the early years and later models. All of the stock Z28 rear ends are about the same in the strength department. There are a lot of options out there for you to build a stronger axle than what you can get from the local pick-n-pull.
The rear end from a sixer is not the same as that found in a Z28.
Nice answer
Old 02-04-2013, 08:48 PM
Greg08's Avatar
Richmond gears + truetrac?
Old 02-05-2013, 06:10 AM
richmond gears whine. i have done one center section install as well, took all day to get it set right. not so lucky as you. had a shop do the camaro gear change for me.
Old 02-05-2013, 09:41 AM
Here is a pic of my carriers and gear. Which series you think it is? Not sure what the numbers are. 200/bl008?
Attached Thumbnails 95 Z28 rearend-2013-02-05-10.30.27.jpg   95 Z28 rearend-2013-02-05-10.30.01.jpg
Old 02-05-2013, 12:47 PM
Somebody else has been inside there before already, you can tell by the chewed up ring gear bolts. And the manufacturers number stampings have been ground off for whatever reason, and those numbers written on. Was someone private labeling somebody else's brand of gears perhaps?
Old 02-05-2013, 01:47 PM
Its a 3.73...but i have no clue what series of carrier it is. I knew someone had been into before I bought it.....Im hoping someone can tell me if its a 2 or 3 series carrier...
Old 02-05-2013, 02:13 PM
like was said in the links i provided they look the same just 1/4 in difference so cant tell for sure from the pict and i cant find the dimensions anywhere.
  #20
Old 02-08-2013, 11:41 AM
I have been looking around online for direction to do my gear swap. i've did one, but its was a open carrier, and I put a mini spool. Ive never messed with a posi one. So does anyone know of a site or a book that gives you details how to replace the gear and pionion? Thanks
Quick Reply: 95 Z28 rearend
