LT1/LT4 Tech 1993-1997
94 z28 no start
Old Sep 16, 2010 | 04:44 PM
osduck5's Avatar
I have not scanned it yet because I do not have OBD I scanner, I do have the OBD II but don't have a converter cable. I know for sure there is no spark at the plugs. Thanks for the schemetics. It will be a few days before I can get back down to troubleshoot. I am going to pick up a OBD I code reader this weekend and try to pull the codes, then depending on what I get, I am going to start with a voltmeter at the connector checking A, B, C, and D.
Old Sep 20, 2010 | 11:31 AM
ChandlerMotorsports's Avatar
Former Sponsor
You're going to definitely want to screen before assuming its the opti. We get buyers with all sorts of problems pointing to the opti who later find out it was something else. So start with the codes. When it comes time to buy, we've got highly reviewed and competitive units. About a quarter of the cost of the MSD\Delco units.
Old Jan 22, 2011 | 07:35 AM
SS/Z28cam's Avatar
Default 94 z28 camaro no start
Ok read thru this tread and I notices on my car I have no spark from the coil pack, I do have fuel pressure. While driving my. Car it just cut out and coasted for awhile to get to a safe shoulder started to crank the engine over nothing. So no start. I checked plugs first no spark, then checked the coil pack no spark, so its before the opti correct? I've replace the igntion switch and ignition control moduel and coil still nothing note these parts are extras I had new in my garage for my car,
Old Jan 22, 2011 | 08:31 AM
if the optical reader in the opti is bad you will not get spark. does the motor turn over but not start or not turn over at all. have you checked the fuses?
Old Jan 22, 2011 | 11:19 AM
SS/Z28cam's Avatar
It turns over very well and no spark, not even off the coil I noticed antifreeze comming out of my thermostast wonder if that did something
Old Jan 22, 2011 | 11:22 AM
that would drain down onto the opti. not good for the opti. even more so with a old opti. any way you could get it scanned for codes? if you cant tell im thinking its the opti.
Old Jan 22, 2011 | 11:27 AM
SS/Z28cam's Avatar
Yes I checked all fuses as well they are all good, also to mention I do have a phython remote start system on this car too it hasn't worked for 3 weeks so I never hit the button also its equipt with anti theift
Old Jan 22, 2011 | 11:29 AM
SS/Z28cam's Avatar
Not able to get it scanned only place that has an obd1 code ready is orielys and they won't let anyone take it out of their store
Old Jan 22, 2011 | 12:43 PM
is the tach showing a rpm when you turn it over?
Old Jan 22, 2011 | 01:06 PM
  #20
SS/Z28cam's Avatar
Hmm I gotta check that if it does then what
