LT1/LT4 Tech 1993-1997
94 no spark.
Old May 11, 2010 | 09:52 PM
flypside's Avatar
Default 94 no spark.
i have a 1994 lt1 and I'm not getting any spark to the optispark distributor. The ignition coil has been tested and checked out. I've heard it could be the crankshaft sensor?? any thoughts?
Old May 11, 2010 | 10:22 PM
Your car does not have a crank sensor. That job is done by the optispark. If the coil is good, check the ignition module, if the module tests good, check all wiring & connectors beteween opti, ignition module, coil & PCM. If all is good, it may be opti time.
Old May 12, 2010 | 12:11 AM
^^^ agree. how old is the opti?
sebi1990
Oct 10, 2010 10:24 PM
draggo144
82-92 V8 Tech
May 25, 2009 03:54 AM
87irocguy
Dec 1, 2008 04:11 PM
ChampionN84
Oct 1, 2007 10:59 AM
